The 5/40 oils
I guess whatever it takes to keep the Hemi from playing 70s SBC and eating the cam?
OP stated his Ram 1500 is V6, which is the Pentastar 3.6L that seems fine on most any oil from what I've read.
The oil cooler leaks however...
It's a Pentastar, not a HEMI, and that problem was supposedly solved with yet another lifter revision in 2018 😉
2018+ shouldn't have lifter problems then? I may look closer at those.
The later years of that generation seem to be pretty solid trucks otherwise. Unfortunately no Pentastars in the 4th gen truck are rated to tow what I need to tow. Otherwise there's a lot of those in my price range.
Correct. Our '19 is supposed to have the updated lifters.
Has anyone taken a closer look at the Walmart available M1 5w-40 FS? Thoughts?
The answer is not really and no one knows if the 5W is better in any respects than the 0W. You would imagine the HTHS would be slightly higher but only Mobil knows. It could be a cost reduced / higher margin product than the 0W, who knows. The only thing we know is FS 5W-30, 0W-40, 5W-40, and X2 5W-50 now all use the same Infineum additive package. I was told this directly by an engineer there and that is both unsurprising and backed up by VOAs. Personally I’d just be choosing between the 0W-40 or 5W-50 depending on use case. I was told the 0W-40 and 5W-50 could be mixed as desired to create something in-between. Not sure I see the point but hey.
Doesn't the Pentastar spec 5W20? MS 6395?
MS 6395 is an engine oil specification for many Chrysler, Dodge, Jeep, and Ram models, including those with 5.7L Hemi V8, 3.6L V6 gasoline, and 2.4L gasoline engines. It's available in a variety of viscosity options, such as SAE 0W20, 5W20, 5W30, and 10W30.
I've been using FS for many years. 0W-40 used to have its pour point at -60°C. It's now at -42°C which is typical for majority group III base oils. Similar story with 5W-40 and 5W-50. Corners had to be cut to keep the price from making leaps.
Additive package compatibility and solubility seem to be at least a partial driver. I doubt the old oils outperform the new versions but who knows.
