OP stated his Ram 1500 is V6, which is the Pentastar 3.6L that seems fine on most any oil from what I've read.I guess whatever it takes to keep the Hemi from playing 70s SBC and eating the cam?
The oil cooler leaks however...
It's a Pentastar, not a HEMI, and that problem was supposedly solved with yet another lifter revision in 2018I guess whatever it takes to keep the Hemi from playing 70s SBC and eating the cam?
It's a Pentastar, not a HEMI, and that problem was supposedly solved with yet another lifter revision in 2018![]()
Correct. Our '19 is supposed to have the updated lifters.2018+ shouldn't have lifter problems then? I may look closer at those.
The later years of that generation seem to be pretty solid trucks otherwise. Unfortunately no Pentastars in the 4th gen truck are rated to tow what I need to tow. Otherwise there's a lot of those in my price range.
Potentially better-shearing stability and higher HTHS.what conceivable benefit does any 5w-40 have over M1 0w-40?
like a real benefit that would make someone change oils? or hair-splitting?Potentially better-shearing stability and higher HTHS.
Shearing stability and higher HTHS are real benefits.like a real benefit that would make someone change oils? or hair-splitting?
He’s making Mr. May look wildAt the rate you're dumping oil any brand will suffice
Hope you are right - I’m not seeing any change in oil pressure with the M1 Supercar - and IIRC - the VVT is ECM controlled anyway …and that problem was supposedly solved with yet another lifter revision in 2018![]()
Ican and it cannot. Everything depends on how good is 0W40 or 5W40. That is why I said "potentially."Cant be. It was written here millions of times that M1 0w-40 is THE best Oil and that Porsche uses 0w-40 for a reason.
0w-40 = Racing stuff! Race proven! Porsche Proven!
Mind if i join you![]()
