It's only you with nothing to base it on that would even suggest that blending two 0W oils would somehow produce an oil heavier than the heaviest constituent.
When I spoke to Mobil about blending their various 0W oils, the only question regarding the final MRV value was that it would be
at some point between the two values and not necessarily based on the proportion of each oil of the blend.
As you may well realise, an oil, in a blend is not a "constituent", it is a complete oil in it's own right, made up of a bunch of individual components...each of which is reduced in concentration by a half (in a 50:50 blend).
Do each of the additives perform linearly (and cumulatively) at 50% of the original treat rate ?
That is your (untested, yet again) assertion, and the reason that I raised it.
I note your statement that it's blending "their" various 0W oils, not randomly mixing someone else's oils.
Yes, I can see that if M1 use the same basic additive chemistry for all of their 0Ws, you end up with pretty much the same percentage of the same polymers, or a linear change in polymer/base-stock viscosity...it's reasonable to assume that you are somewhere in the middle.
Doesn't automatically lead (posit, assertion, or even assumption) that it is true when differing polymers are used
