Tested the alcohol % in my fuel today
I tested regular Shell 87 gas at a store I frequent. It came out to be about 6%. The Shell station says "up to 10% ethanol." I'm not sure if my state requires 10% ethanol, but I'm perfectly fine with less of it. The reason I tested it is that my 08 Jeep runs better and smoother on ethanol free gas and the last 6 or 8 months it has been running better on the Shell. I suspected a little less ethanol content, so that's why I tested it. I checked some Sunoco gas, just to see if there was a difference. It appeared to be at about 8% ethanol.
Could it be that it comes to the station at 10%, but maybe it is mixing with water in the bottom of their storage tanks, causing a lower percentage to be left in the gas that gets pumped out?
Originally Posted by Ded Mazai
Don't you want to prove that this type of measurement is accurate?
There is at least one analytical chemist on the board. I'd ask him. I do know that 5 mL of water plus 5 mL of ethanol does not equal 10 mL of the mix.
