Does E85 make more power than gasoline in flexfuel vehicles?
Brittany 🇫🇷
Today something interesting happened on a long drive. Decided to fill up with standard gas, I like to do it once every few months as it appears to be good practice to remove the deposit build up made by E85.
My car has a flexfuel conversion kit which works with an ethanol content sensor. To be clear, all it does is increase how long the injectors are spraying based on the the ethanol content. Fuel trims aren't affected granted there's no issue with the fuel system keeping up with the injectors flowing more fuel.
What happened is that the car felt like it lost some power and torque in the 2000 to 3000 rpm range once filled up with gasoline and I was thinking I had an issue. It also downshifted on a incline on the highway which never happens usually.
I'd like to hear from owners of flexfuel vehicles if this is common or unusual. It makes sense since there should be more spark advance with higher octane fuel but it seems unusual to be able to feel that much difference between regular gasoline and E85.
You might find some information in one of these previous threads:
Is it be possible that when the sensor sees regular gasoline that it doesn't just revert to previous maps, it goes to a more safe mode?
After a couple tanks of gas, does the issue go away?
Alcohol tends to have more punch than gasoline but needs more fuel to get that punch.
Owners manual has a lot of useful information about using flex fuel. Miles per gallon will go down a bit, the giddy up will go up. We may all be using more of the flex fuel if the speculation market keeps sticking it to us. The summer travel season is about to be expensive.
My 2012 Pentastar van is setup for E85 from the factory but I have never run it and have no desire to… but I guess it’s good to know I could in case of emergency.
Then again, I don’t believe I have ever seen E85 at a pump in the Southeast 🤷‍♂️
E85 is higher octane so the engine will put in more timing as it notices, through the knock sensor, that it can add in timing. This will give you a bit more h-pees.
But the injectors are adding more fuel (more volume of fuel per a given amount of air) so even though the engine may make more horsepower, it uses more fuel than it would using normal gasoline. So you lose some emm-pee-gees or (umm-puh-guhs if that's your preferred vernacular)
I'm curious to know what makes you think that E85 leaves deposits? In my experience alcohol (E85) burns much cleaner than gasoline.
As far as your question, E85 in the USA has an octane rating of ~106. If regular gas is 87 octane then you are up 19 points. The ECU will advance timing to compensate for this. When the ECU advances timing, yes it is possible to make more power. Our 2014 T&C is Flexfuel and we have been using E85 on and off for a few years and pretty regularily in the last 8 months. I don't notice too much difference but this thing is a dog compared to my 2012 Ram with a CTD.
Anyway, how it works in my brain.
Bottom line though, considering the fairly significant energy density difference between EtOH and octane if there is more power it must come at the expense of fuel consumption.
E85 has more power potential than E10 or straight gasoline. There's two mechanisms by which this is possible. The first is the heat of combustion where ethanol has a slightly higher BTU/lb of stoich air compared to gasoline. The second is the heat of vaporization where ethanol has a much better cooling factor. The cooling factor has a bigger impact on low to mid rpm torque which likely explains your power loss.
we see about 15-20% drop in mileage but prices are 20% or greater so E85 makes economical sense for us.
It can if tuned for it. Sometimes the spec is buried and not widey marketed.
He’s an example, the L83/5.3L GM V8 is tuned for 87 octane and has two output ratings.
But the 6.2, which is tuned for premium fuel, has the same rating for gas and E85.
The truth is a bit more complicated. Like @RDY4WAR mentioned, the "heat of combustion" is the amount of heat energy that can be obtained from the fuel during combustion. However, he was only partly correct: ethanol has lower heat of combustion than gasoline (on a mass basis or BTU/lb like he said) BUT its stoichiometric ratio means that more fuel must be added to the same amount of air in order for it to be completely combusted. It has a higher heat of combustion at stoichiometric ratio (which will necessarily require more ethanol than it did for gasoline). I hope that doesn't sound like nitpicking because what he meant to say was correct, just the way he stated it wasn't quite right.
To get back to your conclusion though, other fuels have different octanes and different stoichiometric ratios; but the octane (which is just how we define the fuel's resistance to pre-ignition), the stoich ratio, and the heat of combustion are not really related. It's not like if a fuel has higher octane then it automatically has lower heat of combustion or vice versa. It's just that the fuels that are available to burn in typical spark-ignition engines happen to land in certain spots with regard to their chemistry. At this point we are getting into a weird intersection of the sciences of thermodynamics, chemistry, and mechanical engineering which has always been fascinating to me!
I'm not sure how my statement was wrong.
Gasoline = 20,012 BTU/lb ÷ 14.7 AFR = 1,361 BTU/lb of stoich air
Ethanol = 12,506 BTU/lb ÷ 9.0 AFR = 1,390 BTU/lb of stoich air
Like you said the heat of combustion is higher when combusted in stoichiometric ratio (true), but then you stated it was in BTU/lb which (like you showed in your second post) is lower than gasoline, not higher (20k for gas vs 12.5k for ethanol). You were right that when combined at stoichiometric ratio there is more heat released -- but then it's not in units of BTU/lb. It's just in BTUs. (You could have said there is higher heat of combustion of the "charge air mass" which is how they would describe the proper combination of fuel and air in a textbook.)
Ethanol adds oxygen to the mixture. That’s supposedly one reason why it tends to result in fewer deposits, but I understand that it can increase power equivalent to compressing more atmospheric oxygen.
Yes, this is why lots of dragsters like to use alcohol fuels, because there is an oxygen atom within the ethanol molecule, which is why the stoichiometric ratio is so different. You need less oxygen drawn in with atmospheric air to combust the same amount of fuel, because you already have some oxygen to start off with. Methanol has even more oxygen (percent by mass at least) and top fuel guys get into nitro too! You can put just a sh** ton of nitromethane into an engine compared to gasoline.
For further reading on the subject (not so much on top fuel dragsters, but on the theory and math behind internal combustion engines) this book is a textbook on the subject and I think you can find PDFs of it for free: https://www.amazon.com/Internal-Combustion-Engine-Theory-Practice/dp/0262700263
I would have to dig through my library to confirm, but I think this book is the one i was thinking of, which is more aimed at the hobbyist and talks a lot about different fuels: https://www.amazon.com/David-Vizards-Build-Horsepower-Design/dp/1934709174
No, it’s not nitpicking at all. However, some of those things can be compensated for in a “regular” engine, but some things have to be designed in from the beginning. So being able to recover some of those benefits in a street engine is impossible.
And I used the word octane as the main chemical component in gasoline, not the octane rating. Every octane rating has the same energy content depending on the adjuncts used to achieve that rating.
