My Own Redline SI-1 Test
Redline SI-1 seems to be a forum favorite and there’s a lot of evidence out there that it works as advertised. I’ve never used it before in any vehicle, so I decided to pick up a couple bottles and perform a test of my own. I’m strictly going to be testing whether or not fuel economy is increased by using SI-1.
The test vehicle is my 2015 Ford F150 with a 2.7L Ecoboost, 6R80 automatic and 4WD with 3.55 gears with 104k miles. This truck is turbocharged and direct injected with no dual injection. I’ve occasionally used Techron in the past but it has been more than 10k miles since I last used a bottle. The truck is leveled 2.5” and has slightly larger tires than stock, so fuel economy has never been phenomenal.
I will be using the on-board fuel economy system for comparisons. Over the past 2578 miles, I’ve averaged 13.9 mpg, and that has remained pretty consistent over that time period. When I first bought it, I was getting closer to 15-15.5 mpg, but that was before it was leveled and on larger tires.
I have a 36 gallon tank, and Redline SI-1 claims to treat up to 20 gallons per bottle. Because of the larger tank, I used 2 full bottles of Redline and filled the tank until the pump stopped with 87 Octane E10, same as a I usually use.
I will monitor the fuel economy for the next 3 tanks, and report back with my findings after each tank. This is maybe not the most scientific test, but it should be controlled enough to show whether or not Redline can make a significant impact on fuel economy in a direct injected vehicle. Hopefully someone finds it useful!
Just the change over from winter to summer gas, which is supposed to start June 1, but might have happened earlier by you, and the rising spring temperatures are enough to skew any results over the next three tanks of gas, jmo. Sorry to cast any doubt, but keeping it real. Having said that Kudos for taking the time.
You bring up a great point and I totally agree. Like I said, this is not a highly scientific test. The good news is that those last 2578 miles included some summer miles, as I hardly drove the truck during the winter. According to my Carfax log, on September 24 of last year, I was at 102,484 miles, and the summer fuel runs through September 15th. So roughly 1000 miles of my baseline “should” have been on summer fuel. Again, not the most scientific, and unfortunately I don’t have a borescope (or the desire to pull the spark plugs on this thing), but hopefully we can see some sort of results.
Supposedly we don’t get the summer gas till June 1st, so we’ll have to assume this tank is not summer fuel, but I can almost guarantee the next tank will be.
Depending on the results of this test and the interest generated, I’ve got several other vehicles here that I can test Redline or maybe some other additives on (including some that are easier to pull the spark plugs on).
Through with tank one. We have some added variables here, so bear in mind this is not a completely scientific test, but I believe we are seeing some results.
I got about halfway through the tank and checked the fuel economy meter, and it was reading 14.5 MPG on this tank, so 0.6 MPG improvement, probably not enough difference to be conclusive, but not insignificant. Now for our added variable- I had to do some towing. I trailered a 2200lb empty trailer 95 miles and trailered a 3350lb vehicle on the trailer (combined 5550 lbs) 95 miles back. Obviously this significantly affected the fuel economy. Immediately after than trip, we were reading 13.1 MPG, but by the end of the tank, it has recovered some and is now reading 13.3 MPG.
The bright side of this is that the engine was used under multiple conditions while the additive was running through the system, including low speed city driving, light load highway driving, and under a sustained load in highway and city conditions.
I’m not too concerned about the extra variable in this first tank because the data I’m really interested in seeing is whether the fuel economy is improved in subsequent tanks after using the additive.
The other result I’ve noticed, and this is 100% not a placebo because others have noticed it as well, is that the truck is idling smoother. There has been a mild “hiccup” at idle for as long as I’ve owned the truck (67k miles, now at 104k, over 5 years). It’s hardly noticeable, and is sometimes more noticeable than other times, but it’s always been there. No CEL, no misfire. I’ve changed plugs, changed the purge valve assembly, nothing helped. I’ve pretty much just learned to live with it. However, it is now gone. The truck idles completely smooth. So there’s definitely been something going on.
I will update at the next tank!
