Tell me if this is correct...
We were talking about using different filters for fuel filtration (I know not oil, diesel...but wait) on another board.
The point was brought up that if you had Filter A (capable of 3 micron at 95 Gallons per Hour) on a 95GPH system and replaced it with Filter B (capable of 3 microns at 33 Gallons per MINUTE), the actual efficiency of Filter B increases (in this case to around 1 micron) because you are running so little actual flow through the filter.
In this case, we were comparing a Racor 3 micron filter (rated at 95GPH) to an Fleetguard HF6604 "3micron" filter (listed at 3 micron on their website, claimed to actually be 99.5% at 1 micron by their techs). The HF6604 is rated at 33GPM...
Thoughts??
This discussion happened a few months ago on another board and I see where it would come into play on this site...I see these guys wanting "bigger" filters and I think back to this idea...would this hold true with oil filters??
steved
I don't know if you would gain anything ..but you might. I believe (that is I reason) that since higher velocity can decrease a filter's efficiency ...that lowering it can increase it. It may not turn out that way in reality.
These MAY share the same media.
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-07), Various GM, Saturn (85-07), Lexus (90-07), Saab (67-07), Suzuki (86-02), Toyota (88-07), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Mercury (81-07), Chrysler/Jeep (02-07), Mazda Trucks (94-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Beta Ratio: 2/20=14/31
Nominal Micro Rating: 20
Gasket Diameters
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Gasket Diameters
Attached 2.834 2.462 0.200
With a slight diminished rate of return as you go bigger ..it appears to get better.
Again, this is just going under the assumption that these share the same media. This was pointed out by another member to me.
