Walmart.Where were they purchased? You may want to contact the retailer and provide the lot number detail to Pennzoil at
Contact Us
Contact us for customer service, questions about your Pennzoil rebate status, motor oil MSDS, or if you need information about Pennzoil products.www.pennzoil.com
Why would you do that? If there is supposed to be an anti-tamper cap or a seal underneath the cap and it’s missing that means, well, it’s been tampered with.I crossed my fingers and put it in already.
I know mobil 1 has a piece of plastic that you rip off I believe the Pennzoil platinum just has like a milk carton where that plastic ring snaps. But nothing snapped and the whole thing just screwed up on both jugs
Right, much ado about nothing here. Foil is not needed when the condition of the cap tells you whether it has been tampered with. Same idea as on typical milk containers.I don't think SOPUS uses a tamper seal on their products.
I don’t know if where is supposed to be a tamperproof cap on it or notWhy would you do that? If there is supposed to be an anti-tamper cap or a seal underneath the cap and it’s missing that means, well, it’s been tampered with.
The whole cap unscrew off. Look like a faulty cap
Oil looked good, I poured very slowWhat did the oil look like?
Faulty how? The point to watch for on these is not nonexistent foil, but whether the cap shows evidence of having been removed. If was removed, someone might've added or subtracted something----or if you're lucky, merely wanted to sniff the oil.The whole cap unscrew off. Look like a faulty cap
And just for that reason I will not be buying pennzoil again. Sucks, I prefer itPennzoil doesn't use foil lid, Mobil1 does
Was that the point of this thread?And just for that reason I will not be buying pennzoil again. Sucks, I prefer it
