1991 Accord fuel tank strap holding bolts?
Personally I would skip the torch. Fuel tank and all.Spray penetrant morning and night for a few days, put a torch on it,and zap it with the impact.
My understanding is that it is a bracket with a welded nut on the other side.I say that the entire rusted assembly will snap off with the bolt in it. Penetrant for a couple days may help, induction heater instead of torch by fuel tank.
Next question what are your plans for if it does come out? What are the plans for when that whole piece crumbles apart? Will it need to go to a shop to get fixed? Maybe just go there.
Can you remove the back seat and then a plate to get access to the top of the fuel tank?My understanding is that it is a bracket with a welded nut on the other side.
https://www.amayama.com/en/part/honda/17511sm4000
It is a available at amayama but the time to wait is March.
Need to replace the fuel pump because Japanese makes from the early 90s used metal not designed for ethanol-ridden gas.
I have searched for online documentation from other forums. The best I got was that one dude said he had to drop the rear sub assembly to access and replace the brackets. I was not able to take a picture, but the bolts not visible and holding the bracket to the body/frame is not so rough.
I current bought some of these galvanized straps for mobile homes.What's your plan for hanging it back up? OE straps or something more universal? I'm with Trav, it's going to break. Picture isn't wide enough for me to imagine what else to hang a strap from, but you'll have the opportunity with the tank out to get creative.
