Got everything for timing belt change tomorrow (aisin kit, new bolts for the idler and tensioner, new accessory belt, 2 gal of coolant). Couple of the question that I have:
1. I'm planning to replace the water pump, so should I drain the radiator and the block before removing the timing belt and water pump?
2. Does the engine need to be supported (with the jack/wooden block) at the oil pan before side mount removal? I'm seeing different opinions on that (although honda manual states it should be supported).
3. I'm planning to change the spark plugs as well, so should i remove them before the timing belt job to make it easier to spin the crank shaft? A bit hesitant to leave the cylinders exposed to the ambient.
Thanks everyone. Feel free to drop any other suggestions, would greatly appreciate it.
Edit: forgot to mention, got the 1/2" Fuel Milwaukee high torque impact gun (1,500 ft/lb) with a Leslie weighted socket, so hopefully it'll take care of the crank bolt
