1998 Forester 2.5L; Timing belt, cams ... trouble
USA
1998 Forester EJ25D replacing water pump and timing belt, and there are a lot of problems!
A timing cover bolt was missing
A water pump bolt is missing
(I didn't lose them. They weren't there in the first place)
The water pump won't come off!
EDIT: I did in fact miss one of the lower bolts. It came right off. :oops:
Also, while trying to get the water pump off, the driver's side cams jumped out of alignment, and I can't realign them! All the marks lined up perfect even after removing the timing belt, but all of the sudden, when I was trying to get the water pump off, the cams got out of alignment! Driver's side, Cylinders 2 and 4, the even numbers
The passenger side cylinders 1 and 3 are fine. Everything is still lined up.
The timing cover is optional. It looks cool when off anyway. Ebay probably has replacements but who cares. Just dont put your fingers in the blender
Now trying to install the water pump, 2 bolts will not tighten and seem like they will spin forever :eek:
Will the water pump be ok with just 4 of the 6 bolts torques down and the other 2 free spinning? Or will it leak? :cautious:
It's getting dark now, and it's going to be cold for awhile, so I don't know when I'll be able to finish it.
No bolts are broken, All 6 bolts are the same size.
Are the two free spinning bolts next to each other?
Was there evidence of carnage on the threads? Seems suspect to me two did this?
Pull the pump and try starting bolts in the holes in question
No evidence of carnage on any of the threads. All 6 bolts are identical.
You likely stripped the threads. Its easy to do with aluminum. Pay attention to torque values, the water pump isnt that tight.
I figured the threads may have pulled when the bolts were removed. With such easy access just putting 6 helicoils in is a simple enough job and never have that problem again. There is a good chance some of the others may spin when torqued down, small diameter bolts in aluminum threads are very weak threads.
