I finished checking the valve clearances and now have some questions about changing timing belt and water pump:
#3 #4
RH LH
#1 #2
radiator
This may be a dumb question, but, is it bad for the cams to roll backwards? In the process of removing the timing belt, the LH cam rolled backwards about 30 degrees, so I rolled it forward back to where it was.
Then, I had to remove the LH cam pulley to replace the water pump, and in doing that, the cam rolled forward about 30 degrees. When I install the new timing belt, I'll have to get that cam back to its original position, so should I turn it forward about 270 degrees to get back to the original position or is it OK to roll it backard? [I'm guessing forward?]
Now I'm hoping that since crank is at #1 TDC, that cylinders #2 and #4 (LH) are not at TDC, and thus the turning of the LH cam and the corresponding opening/closing of valves won't have a risk of the valves hitting the pistons.
I don't know if this is a valves and pistons non-interference engine; the diagrams in the OEM service manual would maybe seem to indicate the pistons are dished where the valves are located.
Thanks in advance for all your help! Louis
- 2000 Subaru Outback 2.5L 4cyl gas non-turbo
- Crank is set at #1 TDC
#3 #4
RH LH
#1 #2
radiator
