My truck is a 2010 Ram 1500 with the Hemi. Little over 90,000 miles on it. Zero leaks or any oil consumption issues, and the dipstick always shows in the safe level at every oil change. Only issue this truck has is a slight lifter tick. Since the truck qualifies to be called high mileage, should I consider going to a high mileage FS or stick with a regular FS? The reason being is I will need to do an OC in the next 7-10 days and I recently discovered the two Wal-Mart's close to me have dropped PUP from their shelves. The options I have there are now PP High Mileage and PP and I thought before I ordered 4qts of PUP, so I can finish off what I have left, I'd ask if it would be recommended to switch.
Thanks in advance for any help! You all rock!
