there's copper grease, there graphited grease, there's mos2 grease and there's ceramic grease, with boron nitride in it. The stuff is white.I think he means the grease made for ceramic brake pads.
Boron nitride - Wikipedia
en.wikipedia.org
That seems like it would eat away at it. I always use anti seize in that spot.there's copper grease, there graphited grease, there's mos2 grease and there's ceramic grease, with boron nitride in it. The stuff is white.
en.wikipedia.org
from the wiki page: h-BN can be included in ceramics, alloys, resins, plastics, rubbers, and other materials, giving them self-lubricating properties.
Not sure if I would call it rubber but I suppose that applies, as it's not metallic.Are you referring to the dull, dried-out rubber type noise that happens over road dips?
Thanks. Err, I hadn't even thought about this detail, was going to just slap them in, without a thought. Now I'm wondering if I need to apply anything.hexagonal boron nitride mixed in grease
not if you don't have it. not worth the cost unless you have issues.Not sure if I would call it rubber but I suppose that applies, as it's not metallic.
It is probably your control arm bushings. Soak both bushings (rear and inner) with silicone spray, and you will probably find the noise goes away.Not sure if I would call it rubber but I suppose that applies, as it's not metallic.
I'll try that after the bushing swap. Am hoping not to deal with those, might have to flip that job to a shop if that is the case. But if it is, might just ignore, car is getting old and needy, no wonder the wife is car shopping.It is probably your control arm bushings. Soak both bushings (rear and inner) with silicone spray, and you will probably find the noise goes away.
The stiffer bushings may reduce the noise temporarily until the bushings wear-in and get softer. The noise is a result of suspension travel and the control arm bushings are dried out, so they make noise when moved.I'm looking at what I could get from Autozone--any recommendations? Would regular old white lithium grease work?
Heck, the rest of the I try to lube up with Fluid Film on a regular basis...
Well, we'll see how it goes. Wife has a high tolerance for imperfect things (she married me after all) and maybe it won't make (much) noise. Or maybe it'll be time for yet more parts. Car isn't young anymore.The stiffer bushings may reduce the noise temporarily until the bushings wear-in and get softer. The noise is a result of suspension travel and the control arm bushings are dried out, so they make noise when moved.
Swapped in the bushings, noise gone.
Not sure but the bars look like they got worn as a result. Weird. [I put an index card behind it to take the photo.]
ThisMaybe your end links instead of bushings. Bushings clunk, links rattle. Disconnect links and go for a drive (secure links of course) and see if noise goes away.
yeah that's why the ceramic grease. this set of bushes won't last as long as the old set. As you see it's important to keep the wear to a minimum, of bushes and bar.Swapped in the bushings, noise gone.
