- Joined
- Apr 13, 2013
- Messages
- 3,258
My 2013 Pilot's front end clunks over bumpy roads. I jacked up the front end and pulled & tugged on the suspension but couldn't find anything obviously loose. It's quick clunks rather than deep ones so my mind went to sway bar end links.... but those are tight.
I did, however, see rust on both compliance (a.k.a. rear LCA) bushings. I had these replaced by Honda a few years back under extended warranty. When they fail, they leak goo but remain black. I haven't seen the rubber get rust dust like this.
The through bolt attaches the bushing to the actual LCA assembly. The LCA articulates while attached to that bushing.
Is the rust dust a sign of something in the assembly being loose?
