PeterZarolli
- Joined
- Jun 17, 2024
- Messages
- 42
And if the clunk persists I will get the shop to do the sway bushings like @Kurtatron suggested! hopefully this is the end to this saga as I had the chassis ears on the endlink, albeit not the sway bar but they are attached lol, regardless when I got the noise on the ears on the ball joints the links didn't light up at all. So hopefully I don't have to replace them! Thanks for the advice!OK big update on the thread, just want to say thank you so much to anyone who has given ideas.
So on Friday, it was at the shop for a diag and they came back to me with a ball joint with play, making the pop and spring bind, making the metal noise. So while the new endlinks that lasted two weeks had torn rubber and did need replacing Im guessing my issue for the clunk has always been with the ball joint. Used some cheap but effective chassis ears and confirmed the ball joint was making noise. So I chalk it up to bad luck on the endlinks.
Spring bind is another story however, after taking it down my driveway, which is insanely steep and I fear the cause of a lot of my suspension problems, the metal noise returned. I looked in the wheel well and noticed that the clip that attached to the strut and hold the brake cable in place was bent and hitting a body panel or some other bolt, bent it back to place, got the brake line in the clip and it is all good.
Now, I suspect my 'alignment' issues were either from this ball joint, or since it mainly happened while braking, I assume the brake line that was just hanging there got twisted / snagged and prevented braking on my passenger side causing me to nearly veer into the opposite lane. The brake line is in good shape still.
So I believe I have my answer, a bad ball joint, which in fairness when I got done last year I was tight on cash and kinda cheaped out on the economy option, additionally I put a lot of KMs on those ball joints, maybe 40k km? So it makes sense they would go.
Everything else on the car seems great! Albeit when I was testing pulling in and out of the driveway I noticed the rear suspension would also make a little click when one end went over the curb before the other. Honestly this just sounds like my old rear suspension compressing and is not that much of a concern as it doesn't happen on any other large or otherwise bumps beside my driveway going forward, I also used the chassis ears on the rear, on the end link and upper and lower control arm (basically that's all the components really back there) and when the noise happened it did not really register on the ears. I assume its either the old struts or some exhaust etc bouncing around or just some inner body panels or something old. I only mention it here incase others have had this issue.
Also today I was looking at getting some rubber driveway curb ramps so hopefully avoid any stress on my vehicle in the future!
Thanks again!
