Binding noise from struts when turning wheel
IN
Recently when i dumped 0w20 in my PS system, I turned the steering lock to lock with both wheels off the ground to push out the old fluid and it made a big fuss with binding noises and an occasional clunk that sounded like it was coming from the tops of the struts. Plenty of resistance too. Any way to free these things up or do i just need to put new quick struts in the car? 2005 Chrysler Minivan
Was going to do both struts this summer/fall anyways because the ride quality has degraded but if this gives me another reason to do them I'll move this higher on the list
I used FCS rear shocks and they're starting to go out already but i guess that's what $15 for a pair gets
I've heard better stuff about the Monroe ones
Despite some folks being OK with quick struts, the fact is most of them are built with inferior quality offshore components. Further, the 2005 Chrysler minivan lineup came with 11 different spring combinations, depending upon engine, suspension type, and other options. And most quick strut manufacturers try to cover all these combinations with one or maybe two different part numbers, often resulting in wacky ride heights, poor handling, etc.
Like Astro said, the best COA is to rebuild struts with OE springs and quality components.
but why engine oil in a system that requires ATF+4
Cheaper, just trying it out, i don't notice a difference at all. hoping the High Mileage will stop my rack seals from weeping too .
3 reasons
KYB quick struts and shocks has been good for me, so that's all I buy now. I seem to get at least OEM mileage out of them, but I haven't had any actually wear out, as the car has been scrapped or sold before they failed. Probably will raise the front end a little but adjust your headlights and go.
The rear shocks in my Focus have ~120k miles on them in two cars now, and work great.
I've found some strut mounts use a common bearing like a 6303. Some can be pressed out, some not. They're not really meant to be serviceable of course.
Others like Kia use BBs in a plastic raceway. I've drilled a small hole and greased with a needle attachment before.
So, the answer is: it depends. Not terribly helpful I know. The best thing is to get your hands on a new one and see how it's constructed.
Maybe some time I'll go the a junkyard and yank apart a strut off a van and size a steel ball bearing. The ones online show it as this flimsy plastic thing
Looking on RA, I wouldn't be surprised if there were BBs in that separate "ring"
In order to access it you'd have to tear down the strut in a spring compressor, at which point most people just install a whole new mount.
If your local AZ or O'Reilly stocks a mount, go fondle it :)
The OE bearings (and most replacements) are inside a plastic cage. This isn't a problem when properly assembled, as the bearings are sandwiched neatly between the upper spring seat and the strut mount. I've been rebuilding struts for the past 15 years and have never had a problem with quality bearings, even though they're housed in plastic. My floor-mounted spring compressor was probably the best 300 bucks I've spent on a tool.
In this instance I could pry the bearing and visually see BBs in there:
The Caravan may not be the same, but I'm guessing it's similar
at $21 a mount vs $48 for a quick strut it would be less labour and more new parts for 27 more dollars. doing just the mount wouldn't be worth it to me but a new bearing would if i could figure out if i can replace it with something basic
do you still happen to have that strut bearing?
I never trust springs in a quick strut. They may sit higher or ride harshly. OTOH if you think your existing springs are tired, this is a cheap way to try to restore life.
At the end of the day it's a minivan with the 3.8......so who really cares :D ??
is there any way to measure this or do you just have to use your butt dyno
Not me. I just want my steering to function correctly and stop the wandering. Didn't mention that in the original post but it did develop a wandering issue maybe 20-30k miles ago and new tie rod ends helped kinda but not entirely
