[/quote] I know Champion makes the Supertech, K&N, and Mobil 1 filters. As far as i know the Mobil 1 and K&N are the same filter in a different color. Is there a difference in the Supertech between the other two? [/quote]
Well as someone said just because it is the same manufacturer does not mean it is the same filter at all. Champ, Purolator, and Wix make their own label and some of the filters they make for other labels are the same as their own and some are made to spec for the whoever is contracting it. The Super Tech is an Ecore filter construction same as the Champion brand Ecore and most of, if not all the STPs are Ecores. The Mobil 1 and K&N are a different construction all together from the Ecore. Do they use the same media?? I don't know, probably not. I know the K&N motorsports series does not look the same as the auto series upon disection and their web site not only shows that but shows a different ADBV. So any assumption that is based on the theory it is made by the same manufacturer and is therefore the same is invalid. Contracters can spec the filter however they want and take bids for the build.
