supertch 5W30?
To OP, are you sure it's Warren? My WalMart here has the jugs from Warren and the quarts from Formula Shell - I think. The jugs and qts used to show WPP at the bottom. Now, only the jugs shows WPP. The quarts show G - the same one from Formula Shell quart bottles. There is also no more stamp of the bottle pouring near the spout, which is a WPP stamp.
I`m pretty sure it`s warren because the jugs don`t look like the Mobil jug`s right now.
Originally Posted By: lexus114
Originally Posted By: awol350
Who cares about specs on it? Use it and sleep well at night!
Ya know, I really love some of you guy`s on here. I ask a simple question and I get this, "Who cares about specs on it? Use it and sleep well at night!" as a response. Real nice. Thanks man.
Hey, at least you didn't get a paragraph response on the cold crank viscocity of Pennzoil conventional.
I found it; http://www.warrenoil.com go under products/data sheets.
Thats the wrong warren. You need WPP which is Warren distribution, who makes Mag 1. They have the super tech pdss if you email and ask for them. Someone did with the super hm a while back.
http://www.wd-wpp.com/
http://www.mag1.com/products.aspx?id=da8fd7e8-8852-41d8-a7a9-11ff79b5b060
The Mag1 PDS are the complete pds I've seen. They list everything!
That's a pretty high starting TBN. Not bad.
Yes, you're right, it might still be Warren / WPP even if the bottle does not have WPP stamped at the bottom. I think Warren just used another bottle supplier for their current stash. In fact, the stamp "G" at the bottom of their bottle also appears in all SOPUS and Valvoline products - two different companies.
