Fred's Pharmacy Oil
California
Anyone got any idea where I can get a PDS of Fred's Pharmacy Oil?
It's got the API SN logo on the bottle.
Bottom of the bottle is stamped WPP. I'm assuming it's a Warren Product but I could not find PDS on their website. Couldn't find one on google either.
Just buy a named brand oil when it's on sale or go to Walmart. Forget about all this no-name [censored] oil.
According to their website https://www.fredsinc.com/freds-brand/freds-brand-items/
They say "Compare to Pennzoil® Fred's Motor Oil"
also it says "if not satisfied bring back for a full refund"
So that would be interesting to do an oil change then drive it and not be satisfied because it does not compare to pennzoil...then do you take back the used oil for a full refund?
I'm not a neophyte. This stuff has the API SN rating printed on the bottle. It's not "censored". It is API certified oil in a bottle that clearly has WPP printed on the bottom of it.
Warren makes many fine products including Magtech, Supertech etc. I was just looking for PDS.
To do that you'd have to compare it with Pennzoil, hence running rings around yourself logically and hoisting yourself with your own petard, which is probably quite painfull.
Perhaps they do petard oil. Its a pharmacy, after all
Originally Posted By: 2cool
I confess ignorance of the required lubrication for a pharmacy.
Yep, that does sound rather comical. After all, there are other lubricants to be found in a Pharmacy.
Warren Performance Products/Warren Performance Packaging is an independent blender of lubricants and will package any lubricant in any container with any label you want to stick on it.
https://start.cortera.com/company/research/k3s9ltl9s/warren-performance-packaging/
It will likely spec similar to this:
http://www.mag1.com/ProductDetails.aspx?id=8185a378-d0b9-4290-a9fa-b1d2d5c06380
