See:Recalling is one thing, what are they going to do to fix these problems. This could range anywhere from (a) examining each vehicle to ensure no problems to (b) replacing engines and full suspension system on all vehicles with new engines and all new parts.
Asking for a friend.
To anyone wondering, but not wanting to search: the stalling problem appears to be ECM related and not an actual mechanical problem. The mechanical problems are designed to occur later on in your Subaru ownership to add "charm" and "character" to the vehicle as well being a great time for the sales department to upsell a new vehicle (or a Fantastic Lease Opportunity!) vs. repairing your "junky old" Subaru with 122,537 miles on it. Nothing lasts forever, after all!
The Subaru flat 6 is the only good engine they've made in the last 30+ years. The Outback in my signature also has a flat 6, the EZ30, and the engine has been "good". It needed a rear main seal at ~90k miles for whatever reason and on older models the oil separator plate was a common issue. Besides that it's a decent car. It's also an LL Bean package so it has an actual limited slip diff in the rear.You raise a valid point. The advent of plastics and CAD of specific parts allows the manufacturer to create a part that has a finite life designed into it from day one. To single out Subaru is a little much though. I myself have a 17 Outback with the 3.6. I've had a window and battery issue and not thrilled with the weak windshield and cheaping out on the pleather seats. While I wouldn't buy one again, mine has been reliable for the about 90k I have on it. The real test is 120k to 200k I say that for any car I own.
My problem with Subaru is that it's death by a thousand cuts if you can't work on it yourself. Valve cover gaskets on most 4 cylinders (how most Subarus are ordered) are a $100 job tops. On a Subaru? I was quoted 250-400. This car is on its third set of rear wheel bearings and third set of front axles at just over 95k -- something to do with the axle geometry or something must be killing them. The second set of both were OEM replacements installed at the dealership.
IF you wrench on them yourself they're not hard cars to work on. Even a novice can pull an EJ25 or EZ30 in 3 hours. I'm pretty sure it's easier to pull the engine to do spark plugs and valve cover gaskets than it is to do it with the engine in place.
I can't speak for most of Subaru's lineup, but the Crosstrek is amazingly slow.That boxer 4 and CVT are either slow or driven by a demographic that drives slow. I'm no speed demon myself so it is saying something for me to point this out.
yep. it’s slow. and it’s even slower until the engine warms up, there seems to be some sort of engine management that prevents full power until the idiot light indicating a cold engine turns off.That boxer 4 and CVT are either slow or driven by a demographic that drives slow. I'm no speed demon myself so it is saying something for me to point this out.
Geezus god don't take your good Toyota monies to the Subaru dealer.
I'd rather have a bus pass than either.
