I have a Coleman Powermate 6250 Peek Watts / 5000 Running Watts with a 10 HP Tecumseh HM-100 engine. It was one of the last ones made before Tecumseh stopped making those engines.
Like many others, I found out that these 3600 RPM engines make enough noise to wake the dead. I added a small car muffler and while you can not tell any difference in the noise level if you are outside in the back yard it is running in, if you go in the house there is a huge difference. With the car muffler it is almost not even noticeable in most of the house. You can still make out that something is running if you are in the kitchen in the back of the house. But the noise level is not disturbing.
I had some carburetor problems and pulled the carb and cleaned it in the one gallon Gunk carb cleaner set up. I also pulled the idle air screw and blasted some Gunk spray carb cleaner through the small idle air hole on the floor of the air passageway just behind the choke plate, into the idle air screw hole, and into the passageways on top of the fuel bowl area. I also replaced the bowl gasket.
Now days draining the fuel bowl (removing it, empty it, wipe out any dirt, and spray it with WD-40), Sta-Bil fuel treatment and some WD-40 sprayed down the idle air hole after each run keeps the carburetor reliable. The ethanol in todays fuel attracts moisture from the air, and then the combination of water and ethanol turns into vinegar (a mild acid) and that causes corrosion. And corrosion in small passageways like the idle air holes, causes blockage of those passageways. Then the carb can't provide the proper fuel / air mixture, and the engine will not run properly. I have never seen any metal with a coating of WD-40 on it rust. And while I have not read anywhere of using WD-40 on these passageways of carburetors, it just makes sense that the WD-40 is a good idea.
I also have a Generac ix2000 inverter unit. Apparently from what I have learned by reading reviews, the pump on the fuel cap can somehow have the O ring gasket come off of the pump plunger and then the pump will not supply the required pressurizing of the fuel tank that primes the fuel system. So if it does not start (especially if using the pump feels like something is wrong) you can easily unscrew the housing of the pump and fix the O ring by placing it back on the plunger.
The Generac also gets the carb bowl removed, cleaned, and sprayed with WD-40 after each use, and of course the idle air hole gets some WD-40 after each run (before it is stored away until next use).
I have talked to some of the tecks that fix these generators, and one told me that on units with a bearing on the end, like the Coleman units, that after several years the grease on the end far from the engine, gets dried out. And then the bearing over heats and either warps the plastic if it is a plastic end, or just has the bearing fail. So after several years of age, it is a good idea to clean and re-grease that bearing. The teck I spoke to said to use Kendal red wheel bearing grease. I could not find Kendal, but read that Mystic red grease is very good stuff, and it is available at any large Wal-Mart in the auto oil section.
Another teck told me that people fry these generators by over loading them. Many people have no clue about how to add up watts, or about how many watts it takes to start some motors. And microwaves are a HUGE load for a few cycles every time they turn on.
That same teck told me of one person who repeatably fried the output of a large portable generator, by over loading it.
One of the things I am very careful about is not over-loading either of my gen-sets.
