Subaru Outback H6 2001 - 0W-20? ...
Replacing the PCV is another good idea.
If you're losing oil, you'll need to find out where it's going and at what rate. Just keep an eye on the level for a while. If a valve cover gasket is leaking substantially, replace them both.
It may just be the odor of used oil that you're noticing, but run it a while and just keep an eye on the level. Find out how many miles it takes you to be down a quart and report back. The UOA will tell you if there's fuel in it once the time comes. Don't worry about a heavier oil just yet; some time will be required to find out what's going on.
Originally Posted By: Hollow
Nope to the 0w20. Too thin and not a recommended viscosity for that engine.
Any quality 0/5W30 will keep it happy.
I used Pennzoil Platinum 0w20 I'm my Taurus. Should I be worried and or change it out?
Same location, similar driving style.
If your owners manual allows for 5w-20, 0w-20 is fine too. A new thread would be better for an entirely different vehicle.
