Do you have a reason to believe that it's sludged? How many miles are on the car? What is its maintenance history? I don't think that motor is a known sludger, and if regular oil changes have been done there shouldn't be any big problems.
Bandito440: My wife and I bought the car brand new in 2001 and we have pretty consistently swapped the oil every 3,000 miles and it came with a 3 year, or, 36,000 mile maintenance plan which we followed in a timely manner. Except for this last oil change. When I took the car in to get our new inspection certificate, the mechanic mentioned that the cars oil is extremely low and that I should put some oil in it "yesterday". But, my wife didn't know the type of oil that the station had put in when it was last changed and some oil was showing at the bottom tip of the dip stick. Also, I was in the midst of this journey from dino oil to synthetic oil and I didn't want to randomly add some oil to other oil in the car based on what I'd read. When I finally took the oil out last weekend I only got about 3-4 quarts out of an engine that should hold 6 quarts! I was pretty alarmed when the reality sunk in. This week when I siphoned the excess oil out of the engine via the dip stick, I place the oil in a plastic container with a lid. Then I read that gas in the oil can blacken the oil quickly as well as making it smell like gas. Unfortunately, the oil that I've siphoned off smells like gas to me. But, I've never ever smelled my old oil before ... So, I'm wondering if the M1 0W-30 AFE is doing its just doing a fantastic job and cleaning engine and what I'm smelling is just grime in the oil, or, if the synthetic oil is slipping back and forth past the piston rings, or, in and along the valve stem(s) etc and getting into and out of the combustion chambers and it's taking gasoline with it. Also, 3 weeks ago I had an inner tie-rod replaced. When I asked him if there was anything else that needed servicing, he mentioned that one of the valve cover gaskets is leaking oil and that I would have to take care of this eventually. I will now take care of this sooner than later. Also, I'm considering purchasing a compression tester to check the compression levels of each cylinder - hopefully, they will all be about the same and the rings and the head gasket are fine ... Should I also consider switching to a more viscous oil? Thanks.
