delirious
Thread starter
- Joined
- Sep 9, 2015
- Messages
- 1,072
Originally Posted By: edhackett
Originally Posted By: JeepWJ19
I am not looking at it from the top. I am looking at it from the side. Even if I was looking at it from the top, counter-clockwise should still be the same direction. Turning it left.
I guess to clear things up, if you look at the picture say I am starting at the middle of the can. I turn it where if you were to put a white dot on the center, the quarter turns should be as followed:
1/4 turn = -> 90*
+1/4 turn = 180* (opposite side)
+1/4 turn = +1/4 turn = 360*
Sorry if that is horribly worded but I am pretty sure that is "lefty-loosey" unless I am just backwards today.
OK, I'm with Bronco79 in not being convinced that you are not turning it the wrong way.
You say counter-clockwise. You need to be turning it clockwise as viewed from the top.
If ->90* means the dot would move to the right side of the can as viewed straight on, that is wrong. You need the dot to move to the left side as viewed straight on. With the wrench handle facing straight back toward you, you need to move it to your left.
The picture of the dents shows the can dented on the right, as if something is pushing into the can on the right, indicating the wrong direction. I would expect the can to collapse toward the left if being turned the right direction to remove the filter.
If that's what you are doing, "never mind". If you are turning it the wrong way, we all get to laugh because we've all done it at least once.
Ed
I will certainly give it a shot
1/4 turn = -> 90*
Ed
