I serviced my 22kW Generac 999cc generator today and I did my homework because getting the OEM filter online the shipping is as much as the filter and I wanted to get this done asap. Generac 070185ES is OEM and cross references to Wix 57145 which I was easily able to snag in town. Even on the Wix website it shows this filter as a cross reference, but little did I know the OD of the filter is slightly smaller which means my filter heater does not fit.
For an overnight hack I wrapped it in aluminum foil to make it snug, I hate to drain the fresh oil and buy the OEM when otherwise everything is the same. Did some research and found that Rescue Tape which is silicone tape rated -85F - 500F is the best option. Does this seem safe and would it be good to last a year until my next oil change (mostly sits idle)? Wondering if I can just do this going forward or if I really should pay up for OEM. I am still under warranty too…. not ideal I know…
Thank you!
Thank you!
