cvlw
Here are the cartoon instructions on the side of the can. Step #4 says 3/4 turn beyond contact. Now, that seems a bit heavy to me. I don't think I can squeak out 3/4 a turn with oily hands anyway.
I’m sure we’ve all heard it by now, but GM used to indicate 3/4-1 turn. After some leaks they changed it to one full turn. I normally use a cap wrench to get this right.
I always tighten as hard as I can with a wet paper towel and one hand then remove with large Channellock pliers. Works for me.Howdy BITOG crew.
I am soon to change the oil on my 2013 Mazda 6. Now that it is cold where I am, it sprung a question... How tight should the filter go on depending on the temps of everything?
Last year, I did the wife's car (2015 Mazda 5) in the cold of winter. I ran the car only to get it on the rino ramps, so not hot. Then did the change. The filter went on as usual... spin till connect, then tighten as far as my filmy hand can do it before slipping, maybe 1/2 to 2/3 turn. The next change was in the spring and that filter was on hard. It was alarming how much effort it took with the toothy filter wrench to back it off.
Any advice on things to consider when changing to prevent a locked-on filter? I don't think I can control the outside temps. Maybe can run the car longer and will definitely keep it less tight.
Much appreciated.
CVLW
I always hand tighten the filter, but not being able to control the outside temperatures, I lube the gasket with 0w or 5w if below freezing and 10w oil if above freezing. In extremely hot weather 30w. Just joking, but if you hand tighten with the gasket well lubed and it comes of hard, so be it. It's better to come off hard than to leak and lose an engine because of not being tight enough.Howdy BITOG crew.
Much appreciated.
CVLW
