it's not the trans pan which is black, it's the silver thing behind it, the mechanic told me what it was called, but I forgot what it was called, it was like the trans case or something, and said i had to take the trans in half and then rejoin it, the gasket is damaged or something like that, see toyotanation post so that ppl don't blame me of posting on here really long posts, etc.
ANnyways, did any product in a bottle cause that, as the verdict is somebody used red loctite and that messed up the oil pan and i will most likely need a new oil pan, this one uses rtv not a gasket but if the aftermarket has a gastket can you use it, and what's a good brand for an oil pan? parts stores oil pans, a used one from a junkyard, or the oem and who is the oem? i see the oem for the caliper is aisin.
Also, does getting your key wet or having the remote get wet bad for it? I was washing my car wiht my keys in my pocket (forgot to take them out) and the keys got wet ,but the remote still works, but the water can't be good for the keys, right? Thanks.
