engineer20
now the camry has a trans fluid leak, could it be from a sheared off bolt from this summer when I tried to drop the pan but failed?
aside from that, it was confirmed by another mechanic this weekend that the water pump is leaking, i don't need to replace the belt, the serp belt is ok but i might as well replace it with the pump and it's got high miles and is rusty anyways
there is an oil leak from the valve cover gasket (he said he could retorque but said that could break the gasket so he advised not touching it) but it wasn't a bad leak, so I could wait till later and would probably have to replace that again, and there's a timing chain cover leak (how should I deal with this)? and the rear struts are leaking oilk the fronts are weak but still ok, and the lower ball joint is bad and should be replaced and then I ened to align the wheels as my tires are all from this year (newish) and they are already going bald on the edges and in danger of having steel belts show!
anybody know how to remove a caliiper? i'm trying to do so on my taurus so I can bring it into this reman place near detroit where they can remain your caliper for cheap. I might as well also bring the other rear caliper in, since a lot of ppl suggest doing calipers in pairs, and having that remainend on the left rear, or do you recommend leaving the left rear alone? thanks. I plan to do the water pump tmrw or next weekend. and then try at the ball joint, if a wrench is stuck you can hit it with a hammer, but i saw some ppl use sledge hammers, is that better or no? i don't have a sledge hammer, so should i get one or is a regular hammer enough, what about a rubber mallet, or a regular hammer is better than a rubber mallett? anybody have any detailed brake diagrams, etc? Thanks. that'd help a lot.
