After seeing several UOAs that show just about all oils being sheared to the next grade down, I have thought about using a single weight oil instead of a multi-weight oil to help prevent this shearing effect. My bike is a 1990 Honda CBR 600F1 with roughly 24,000 miles on the odometer and a 12,000 RPM redline. The manual either calls for 10W-40 or 20W-50. If I do decide to run a single weight oil, I can not decide whether to use a 40W or 30W oil. I only ride during the spring/summer/fall months hear in northern and central PA. The coldest startup my bike may ever see is about 55-60 degrees. I've have been sugested to try a 30W oil but for some reason I would feel more comfortable with a 40W oil. The newer CBRs now run 10W-30 from the factory but I don't know if my bike would be safe using a 30W oil. If I was to use a 40W oil, at what temp would it be NOT safe to start my bike? Would I be safe running a 30W oil? I really appreciate your feedback.
