STP Extended Life Oil Filter S10415XL
Show Me
I went Autozone to check out two filters for my 2008 Volvo XC90 3.2L. This is the Extended Life "10k Mile" filter. Looks somewhat similar to the OEM M+H filter. Pretty sure this came with a silicon O-ring in the box. You can also check out the other filter I'll be posting that claims it's the "5k miles" version HERE.
The endcaps do look very similar to Mann cartridge type seen on BMW cartridges and others. Appears to be a well-made cartridge.
99.9% sure it's a Chinese "Knock off" of OEM Mann cartridge but agree with you they look pretty darn good.
I like the design. My Baldwins are Taiwanese and work great and dirt cheap too. VW models
Thread 'Baldwin-Hastings P40010 -LF722' https://bobistheoilguy.com/forums/threads/baldwin-hastings-p40010-lf722.370035/
Only thing I can think about that would cause me concern is doing a c & p. Not sure how to get that foam style ends off short of just cutting them off. 😅
Any ratings relevant to particle size filtration or dirt holding capacity?
Here's the lousy Product Description. :(
STP Extended Life Oil Filters provide maximum protection for your vehicle's engine. Its superior synthetic blend media traps contaminants with 99% efficiency over the life of the filter.
  • checkmark
    Engineered to provide up to 10,000 miles of engine protection, when used with synthetic oil
  • checkmark
    Built with advanced synthetic fiber blend media with 99% Multi-Pass efficiency and removal of particles as small as 20 microns
  • checkmark
    Includes Silicone O-Ring/s unaffected by extreme temps as low as -40s Degree Fahrenheit and as high as 400 Degrees Fahrenheit
99.9% sure it's a Chinese "Knock off" of OEM Mann cartridge but agree with you they look pretty darn good. ...
IDK, Mann has filter operations in China, seen a good number of spin on filter anecdotes from them with that coo. 'Could be' they are making the topic cartridge for AZ STP XL there. In any case, as noted, on appearance looks to be a quality cartridge.
I know the Mann version would show "Made in Germany" but as you well know things change as fast as a finger snapping. Also, Interesting on my scouring the net appears the Champ Labs P842 is sourced from the exact location.
https://luberfiner.com/part-number/?partno=P842&partkey=000388981#parentHorizontalTab1
I've sent an email to Champ Labs to see if they tell me anything.
  • checkmark
  • checkmark
  • checkmark
What info does Mann provide for their version ?
Looks like a PG Inc filter made at the China "Advance Filtration Inc" (AFI) factory.
If it's reassuring, been using their S11473XL extended life filter for my Merc GLC300 4Matic since day one along with Mobil 1 ESP 0W30, and all good after three oil changes. Only drive about 6,000 miles per year with vast majority as short trips 2 to 5 miles, wife's vehicle. AutoZone seems to be constantly running a deal for the purchase of the two (5 quarts) for about $40. Still need an extra quart to give me the six quarts needed for the complete fill.
