Originally Posted By: Clevy
From what I've read on this site mazda's new 0w-20has a very high viscosity index,and really high moly count.
Go to caterham's profile and search his comments. That guy knows this stuff really well. His posts are getting me off my thick is better thinking since he posts fact based on data,not feelings or butt dyno.
Perhaps pm him,or he may even answer in this thread.
I've been reading quite a bit about the Toyota and the Mazda 0/20. Very intriguing...
Originally Posted By: fdcg27
OTOH, PP would also be a very good oil to try, and would be the equal of either M1 flavor in your use.
Does PP come in 0/30? When you say it's the equal of M1, what do you base that on? I have noticed a lot of folks on this board seem to run Pennzoil... Not many folks run it in my area.
Originally Posted By: DuckRyder
What's your motivation for moving away from the M1 5/30?
What are your expectations of the new oil? (What will it do that the M1 will not)
My vote is stick with what you are doing and do a couple UOA's before changing.
Just intrigued with the idea of a 0/30 and the possibility of better cold start wear control (although, here in Memphis, we don't get much very cold weather - rare for it to drop into the high teens for more than a day or three, better performance, and marginally better fuel economy).
As I said, I'm reluctant to switch away from the EP. It's more just curiosity to see how much differently my engine would run with a 0/30, especially going into winter.
I like your suggestion - I have ordered a couple of UOA kits, and will post them up when I get the results here in a couple months.
Originally Posted By: Tones
EP is not worth the extra money for your OCI. I run the AFE in my vehicles. Either the 5W Mobil 1 classic or the 0W AFE are great bang for the buck.
It costs me three dollars more per OC for the EP vs. standard M1. The three dollars is worth it to me for the warm and fuzzy feeling it gives me
...and the braggin' points with my buddies for using EP!
Anyone aware of any negatives that would exist by using EP for a 7500 mi. OCI?
(I don't have a problem with extending that OCI if my UOA results are promising.)
AFE comes in a 0W-30 flavor and that's what you should use.
Looking at the UOAs here, the AFE seems superior to vanilla M1 and probably equal to EP.
Not true. XOM has three levels of anti-wear additives for their non-racing street oils. For example, they publish phosphorus and zinc additive levels:
High performance (0W-40, 5W-50)= 1000/1100
EP/standard (5W-20, 5W-30)= 800/900
AFE (0W-20, 0W-30)= 650/750
That's about a 20% step down in add pack content for each step. There is NO QUESTION that Mobil1's AFEs contain the weakest add packs of any of their oils. This doesn't mean they are bad oils it just means do not mistake them for "extended" range oils like the others. They are designed for max fuel economy, nothing more. So, if you like EP, do not assume that you don't give up anything going to their 0W oils. Hint: there are better fortified 0W oils on the market.
I noticed that yesterday as I was browsing through the PDS's for the different M1 varieties.
What about the new "organic" add-packs that I've been reading about over in the VOA section that don't show up in VOAs...such as what's used in some of the new API-SN/GF-5 dino oils (e.g. VWB)? Possible that XOM could be using that technology for the AFE to compensate for the lower levels of traditional additives?
AFE is the newest "family" of (retail) formulations for M1, right?
Correction here. AFE has the same high temp and low temp ratings according to XM as EP, and higher fuel rating than both EP and reg M1. AFE also is rated higher by XM than reg M1 in the high temp and low temp areas. This is according to the back of the bottle. As for OCI, AFE has the standard 10K warranty, the same as reg M1. Yes, AFE oils are designed for max fuel MPG, but their base stock is very good with a MRV @ -40C of 9200(0-20) showing an outstanding base stock with few equals.
Interesting...can you enlighten me on what "MRV" is?
EP>M1>AFE
What are you saying here? That EP is better than std. M1, and std. M1 is better than AFE?
