Originally Posted By: jcwit
My milage has increased on a total avg. over the six months I've uses MMO, verses the 6 months prior to that. Also I believe the engine runs better, whether it actually does or not is in actuallity imaterial,
+1
I have also done my own extensive testing and my truck definitely gets about 1 to 2 MPG better with MMO than without. Will MMO increase MPG for every single person who tries it? No. Will it increase MPG on the very first time you add it to your gas? No, it won't. It took about 6 weeks of use in every fill-up before I noticed any increase in MPG.
My truck runs better with MMO. Plain and simple. I know my truck like the back of my hand and there is a definite increase in power and it idles smoother, has stronger and more even acceleration and the throttle response is better with MMO than it ever was without it. With MMO in the oil, my engine idles even better and just has a more powerful performance. I don't use MMO in my oil all the time though, just for the last 1000 miles before an oil change. I really believe the positive effects on my engine from having MMO in the oil prior to an oil change help my engine run better during the first 2000 miles of an OCI. In winter months I use MMO in the oil for a longer period of time and my engine runs great then too, and cold starts in 30 to 40 degree weather take no more than a split second turn of the ignition key.
My own experience with MMO is all the documentation I need. It works and it works very well. It gently cleans the fuel injectors, it lubes the fuel pump and it helps to offset the negative effects of ethanol. MMO increases my compression and cleans the piston rings, providing a better seal. That and its UCL properties help my truck run better than it ever did without MMO.
I don't use MMO strictly to improve MPG. The MPG increase is a very welcome side effect of the UCL, lubrication and cleaning properties of MMO. It works great for me (and countless other people too) and that is all I really need to know. And I have yet to come across a single post or article online saying that MMO in gas and/or oil damaged an engine.
MMO is a great product. My only complaint is I wish I had discovered it sooner.
