So, for the past few years, my Cherokee has had a LOUD rattling / banging over bumps.
Since it is lifted - the rear upper shock bolts broke. I have a "custom" system of bolts through the crossmember, welded, to hold in the shocks.
I assumed it was the upper shock bolts and mounting system causing the rattle over bumps. Saturday I had them rewelded and that didn't fix the problem. I decided the only way it was going to get fixed was if I had a whole new crossmember welded in. Which wouldn't be cheap at all. I figured I would just live with it.
On Sunday, the local Jeep club had a bit of a run that involved a lot of seasonal highways. I had a passenger riding with me that also had a Cherokee.
After about 2 hours (out of 12) into the run, my passenger had enough of the constant rattling ... it was driving us nuts on the seasonal highways constantly banging.
He mentioned how it sounded similar to the hatch closing. I disagreed, because I "knew" it was shock mounts.
The noise irritated him enough that he hopped over the seat and crawled into the back to see where the noise was coming from. Pushed on the hatch and, sure enough, the noise stopped.
The rubber bumpers were completely dryrotted.
This was the temporary solution to keep the hatch quiet - did this on both sides:
Last night I bought new bumpers. Problem solved! After two years!
