Something To Ponder...
College Dorm...
It's been mentioned on here that the HDEO 15w40's are good down to about 15F.
At 15°F, Delvac 1300 Super comes in at 3,755 cSt!
Well 15W should be good for -15C or 5F..3500cP
[ January 26, 2005, 08:25 AM: Message edited by: Al ]
FWIW
Pennzoil High Milage 10w40 is a derived 3452 cSt @ 9F
Speced at -13F
cP = cSt x g/mL
Using above number 3452 x. 87 = 3003 cP
Thumb rule: cP doubles every 5C drop for dinos, although, things get pretty unpredictable in this temperature region.
Chevron straight 30 is 3033 Cst at 15f. A straight weight 30 is better than a 15w40 at 15f?
I guess I should qualify that statement a bit. API Group I and II base oils have been shown to roughly double in CCS viscosity for every 5°C reduction in temperature. Those containing higher VI oils, such as API Group III and IV, increase viscosity by a factor of ~1.7 for every 5°C drop in temperature.
So in short, that doubling factor roughly applies to the CCS in the appropriate temperature region.
4,000 @ -20 per my old data sheet for 1300S.
Pretty decent for a dino HDEO.
Jelly, the actual number doesn't really matter as long as it's within cranking specs. My manual states that a 15w is good down to -20C. I used M-1 15-50 last year down to -22C..the coldest it got in Toronto.
I just found it very interesting that we argue over a few cSt one way or another on the top-end (212F) yet rarely if ever looks at that same oils viscosity when exposed to cold temperatures...turning into a gelatinous blob when your engine demands (requests) fluid lubrication can't be a good thing...
Interesting discussion, Jelly. It was worth a ponder. Unfortunately, your subject matter got accidently highjacked by another thread.
