- Joined
- Feb 20, 2022
- Messages
- 618
Good evening BITOG world, I'm about to embark on a project to resurrect my brother in law's 1983 CJ7 Wrangler Laredo that has been parked for almost five years. Has been in the family for over 20 years and it's time to move it on to a new owner.
Parked in Phoenix, AZ so a good climate for prolonged storage, last drive was fall 2020. Since then it has been started periodically, last time about a year and a half ago. Not sure when the last oil change was.
Last time the Jeep was started, it emitted a lot of smoke (blue, I believe). 15X,XXX miles on the inline 6, possible PCV issue but more likely stuck or worn oil control rings.
Looking to get it running and driving in order to sell it. New battery will go in, and oil will be changed to 15w40 HDEO with a possible very short time flush depending on how the old oil comes out.
Old fuel will be siphoned from the tank and vacuum drawn out of the fuel line going to the carb.
Any recommendations on oils or oil additives to help remove deposits? I'm not interested in doing anything as aggressive as a piston soak, just a mild cleaning of the engine best we can before we send it on to its new owner.
Wrong section but if anyone has fuel system cleaner recommendations I'm all ears. Pic for attention:
