Originally Posted By: SteveSRT8
Demarpaint is correct. Fuel dilution is an issue even if you figure out a way to keep the valves clean.
One of our mods needs to go back to school. By playing with valve timing Ford may be holding this issue at bay. Ever hear of "reversion"? Here's a link:
http://www.circletrack.com/enginetech/ctrp_1011_race_engine_reversion/index.html
Extrapolate this idea a bit and you can see how this can both be used to help and also hurt the issues in a DI engine.
But as stated MANY times here by Demarpaint and myself and many others, we'll watch while all you happy 'developers' run the beta versions!
One of our members needs to be respectful of others.
I like your words IF, MAY and also
hurt of the issues in a DI engine. Also the statement "Fuel dilution is an issue
even if you figure out a way to keep the valves clean" is a nice (and accurate) comment.
How about the fact that DI is causing problems that are not needed in everyday operation. Problems that normal motors get along just fine in daily operation WITHOUT any worry of timing this, deposits that or any other issues.
If a normal motor can provide the same end result (except a few ticks on a form so they can have more "points") without the DRAMA then I'm going to go with a normal motor.
In fact I did. Just bought a new vehicle and some of the competitors had DI motors (I did not look at them due to having a DI motor) and the vehicle I decided on and is in my garage had DI as an option. I passed. And am VERY happy I did.
Same with my Dad who just bought a new vehicle in May. And one other friend who bought one last month. Choices were made and all of us know one thing,
a simpler motor won out in the market place. Uninformed buyers or ones that want to take the risk can buy the DI motors. As long as I can get something without or someone asks for my opinion on buying one a non DI motor will be the choice until I see the FACTUAL results of a DI motors going many many miles WITHOUT any problems.
And normal maintenance is not $200 cleanings every xx thousand of miles. If I can have engines go
HUNDREDS of thousands of miles with
NO injector issues (or cleanings other than a bottle of something every 30k miles) a DI motor better do the same before I see one as an owner.
Bill
PS: Can not even read your link except the first few lines.
