The sky active engine can reach 14-1. However, compared to 20-1 effective compression in an eco boost it is not the same severity In the amount of fuel that can be mixed in the combustion chamber. And different than a turbo like all naturally aspirated GDI designs, the Mazda produces its torque at higher rpms.
As an aside I think Mazda is onto something with their technology and exhaust manifolds that control charge temperature through better flow. Very old school fundamental technology being optimized to make GDI get more efficiency out of fuel.
Originally Posted by KCJeep
Valvoline and Castrol both moved away from sodium once the info was out on LSPI. OP has old stock though...
I don't believe Valvoline's consistently awesome used oil analysis are related to sodium, but whatever it is they consistently use as an additive that does not show up in a 30 dollar UOA. Super secret juice ha ha. Valvoline always looks bland and uninspiring in UOA/VOA's, yet the results for "wear numbers" are generally fantastic. This has been consistent for many years.
As for the OP I don't think one OCI is going to make the sky fall, but I'd not repeat. That Mazda may not be turbo, but if it has "Skyactiv" the compression levels are very high. Isn't that exactly what a turbo does?
