So is Blackstone still the best?
Fayetteville, NC
I am hoping to get a used oil analysis in the near future.
Is Blackstone still the best, go-to used oil analysis lab here on BITOG? or is there a different lab I should consider? If yes, why?
Let's say cost is not a deciding factor for now.
Thanks.
I'm not sure they were every the best.
but they are certainly a popular choice.
then main thing is to go to the same place dont switch labs often as the results usually arent comparable.
Originally Posted By: fdcg27
Polaris is the go-to lab, IMHO.
I was thinking of trying them out what are there prices?
And why is Polaris better? (than B-stone)
(this will be the 1st UOA for this car so it doesn't matter which one I use, ALA it's a decent, accurate lab to stick with I guess)
When a lab gives you a (?) question mark instead of a value or reading for coolant level, then I would definitely look elsewhere. I have seen more than a few results like that from [censored].
Thanks.
Dyson Analysis's "Basic" service has, by far, the most complete test suite dollar-for-dollar of any oil analysis I've ever seen.
I think any lab will give you the numbers that you're looking for. From there on, it's all about preference.
I personally like Blackstone because their report is easy to read. Other labs have me turning my laptop sideways just so i can read the data...
+1
B/S Labs matched Analysts Inc. in wear metals in a comparison sample I had tested a few years ago. Some Labs have more in depth testing.
Used a couple of the Wix test kits. I liked everything except the pokey turn around, but at $7 each on a Amazon blitz deal I'm not complaining. Nice that the TBN was included in the price.
If you buy pre-paid kits in ten packs, you get them for This is a pretty good deal, and the basic test does include TBN.
You can buy a pack of ten or two and split it with another memeber or two.
A few of us here did this.
Dyson Analysis (TestOil) is the best, hands down. I've used Blackstone and most recently Polaris quite a bit when money is an object. They have issues, but are economical.
which labs are you referring to?
I like Blacksone, and they are my personal choice, but they are not the only decent lab around; many choices.
This is not a used oil analysis; I'm moving the thread. -MOD
I've experienced a few anomalies with Black Stone. First, I sent samples in for two different cars a couple weeks apart. They both came back extremely high for copper. I did used oil analysis on my next OCIs for each car and they proclaimed the copper problem cured.
Later, I sent a sample from a 6k OCI with Valvoline conventional and the TBN came back at 9.8. That's higher than virgin Valvoline conventional!
For my most recent UOA I tried Polaris. First, I found the form incredibly difficult to fill out, I didn't understand some of the questions. Second, I felt like their service was much slower that Black Stone. Third, I felt like their report was difficult to understand.
So, issues aside, I'm still leaning toward going back to Black Stone unless someone has another good suggestion.
is there a different lab I should consider?.............Let's say cost is not a deciding factor for now.
Thanks.
Dyson
