Originally Posted By: mattwithcats
The door sticker is for stock size tires, and maximum ride comfort.
However, for maximum tread wear, look on the side of the tire. It should say "max pressure XXX psi".
Don't exceed this, but put two and a half to five pounds less than that number...
This advice is a little bit out there, there are some tires that say max is 44-52 psi.
It's the car manufacturer that knows what the correct tire pressure should be and you're always supposed to go by whatever the car manufacturer says. They're the ones that know what the handling characteristics of the car would be at a whatever tire pressure they recommend. The tire manufacturer on the other hand doesn't know anything about the car it goes on so can only recommend a max inflation pressure.
With that said, lower tire pressures do contribute to a softer ride so you can usually go a few psi above what the manufacturer recommends.
