Good call putting the PU in by itself. Determine how long you're gonna run it and pull the valve cover 1k before you dump it to see what it's done, then ad the MMO for the last 1k.
When I ran PU in my Corolla, it didn't seem to do much in 2k, but I'm sure it was loosening everything up. The oil was still very clean and new-looking at 2k when I added 1/2qt of MMO; when I dumped it at 2738 (or somewhere around there) it was dark and clearly dirty, not just oxidized. I can't put all of that on the MMO, though I've seen it work some miracles I have never seen it do much in less than 1k; I'm confident the PU wouldn't have done much on its own, as it hadn't been doing much visible cleaning in the first 2k.
With everything you've tried so far, straight PU might just be the ticket, though; it really is a great oil.
I doubt MMO will do much in 1,000 or 2,000 miles in that engine. I'd stick with straight PU, and if that doesn't work give MMO a shot following their directions. I have a feeling PU and its low Noack might show some results though.
