jefferson997
- Joined
- Sep 25, 2024
- Messages
- 21
The mixture is fine and that's going by the plugs. The bike had the stock stuff on it when I bought it and it had the problem so what I have done to it didn't cause it.
Nice increase in compression. Was the Nighthawk using excessive oil (along with lower compression)? You didn't mention it, but I gather it was since you suspected stuck rings.I run 2oz of MMO in every tank of gas in my 92 750 Nighthawk. Helps in the tank, petcock, carbs, compression, and exhaust.
Tested compression before 140 135 145 140
Now 150 150 155 155 That's power you can feel.
Got the bike at 20k miles, so sat a lot. Suspect stuck rings. Bottle only $8 at Wally World.
No excessive oil use that I noticed. Hard to know what compression test should be, but I thought it was low so tried the MMO.Nice increase in compression. Was the Nighthawk using excessive oil (along with lower compression)? You didn't mention it, but I gather it was since you suspected stuck rings.
Nope, bought it, tested compression, rode it 4k miles that first season tested again, those are my first #'s.My experience is if there is not an oil use issue, the rings are sealing. At that point, when there's a compression increase like you've experienced, it can be from simply running the bike because it sat for a long time. Especially if you checked comp right when you got it and then a few miles down the road after you began riding it. Like you said, the MMO is good for more than just the top end so no downside there.
I purchased this bike with 21,000 miles on it. They are known for sticking rings especially in the center cylinder as it runs hotter than the outboard ones. It has always used more oil than it should and a compression check revealed the center cylinder was lower than the outboard cylinders.
I use TCw-3 and Stabil Marine in gas for my mower and generators year-round. I also winterize my motorcycles with it.So I've now stumbled onto various posts about running TC-W3 2 stroke oil in your gas at 1 ounce for 5 gallons. This is in Corvette, Camaro, etc. forums so
you know they baby their rides.
They never mention increasing compression.
I think that is the major thing that is happening.
2 stroke oil is WAY cheaper than MMO.
IDK
