The Valve Experiment
I've run TCW3 in my bike for 18 years but it has no cat to worry about. Besides a bit of added lubricity it keeps the combustion chambers clean. I've never been inclined to try it on any engine with a cat and anyway modern engines are much more accurately fuelled.
When Lake Speed Jr. talked about lubricity in fuel reducing wear, I believe he was referring to modern, EFI car engines which tend to be even a bit better in that regard than EFI motorcycles. So it is not just for older, carbureted engines and the like.
Isn't the Versys a liquid cooled engine?
It is, and it definitely helps. My first bike was an air cooled Ninja with a carburetor, and I definitely notice a difference with the Versys.
With that said, it's packing a decent amount of power and high revving within a smaller volume that it likely could benefit from any extra added help. It could potentially be detrimental in cold temps though, but I think likely not.
Oil in gasoline lowers the octane. Lower octaine means it is easier to have knock and LSPI...,
Thank you, and duly noted Jim. I had wondered about the octane change and if I should go up to counter balance. I already have been running one grade of octane higher most of the time while doing this. My bike calls for 87, and I've been putting mostly 89 in it, but I'm wondering if I should go up higher?
I add 1oz of TCW-3 2 cycle marine oil to my 5 gal gas cans...
Do you go up in octane when you do this?
I'm assuming that since you're still doing it, you haven't noticed any negative effects?
Thank you for sharing the above.
This is the video in which Speed Jr. talks about this issue:
To be fair, Shell is using a different lubricity fuel enhancer than 2 stroke oil in all likelihood (I don't remember if the exact chemistry was mentioned in the video at the moment. I will probably re-watch it at some point in the near future and if it is mentioned, I'll report back).
I learned about the 2-cycle oil trick from other motorcycle forums. People use it to keep carbureted bikes from gumming up or corroding. The oil leaves a thin film in the fuel system that protects during periods of non-use. I use it for winterization of my motorcycles and my metal gas tanks are spotless and the bikes start right up in the spring (both are fuel injected).
The lawn mower and generator usage came from people experiencing stuck intake valves on outdoor power equipment. The intake valve stems would become gummed up and stick open, causing the engine to not start (especially on Hondas that have plastic cams and light valve springs). The TCW-3 adds lubricity and helps keep the valve stems clean, along with the carburetor anti-corrosion benefits.
Later I learned that people noticed cleaner pistons and combustion chambers while using TCW-3. I wasn't really worried about this, but if it is a benefit, I'm fine with that.
I do not go up in octane. I use regular pump gas 87 octane with up to 10% ethanol. It's such a low oil mix ratio (640:1) that I haven't had any problems. The owner's manuals for my Honda motorcycles state 86 octane or higher, so it's most likely still within spec. The mower and generators don't seem to care either. I've burned old 50:1 mix gas in them to use it up before without any noticeable performance issues. On my one motorcycle that required premium gas, I just added a squirt of TCW-3 and stabilizer to the tank when filling up in the fall before putting it away for the winter.
Some people use an upper cylinder lubricant (TCW-3 or Marvel's Mystery Oil) in their cars and bikes at every fill up. I find that it is a hassle to carry the oil around to squirt the tank every time I stop at the gas station. I just want to fill and go. All my cars have gone well over 150K miles without it and still running fine when I sell them, so I don't see a need for daily use.
I'll look around for the video and share it here and people can judge for themselves. One man's evidence might be another man's hearsay I suppose.
Mhm. There are standard tests for wear and that’s what I was referring to, after that well…
LSJr isn’t quite as definitive as imagined sometimes.
I imagine like every human on this planet, he occasionally gets things wrong/off. But he does have a lot more knowledge, education, and real world experience than myself, and I suspect probably something like 98 to 99% or so people on this forum.
I respect your skepticism-I think skepticism is a very important trait to have, and process to engage in. With that said, I've observed over the years that skepticism needs to be counter balanced by equal parts open mindedness, and at least a little optimism/positivism/enthusiasm, otherwise it too easily can become knee jerk cynicism (which is a dark path that I prefer not to ever tread).
Just wondering, do you have any connection to Lake Speed Jr?
Not any personal or business connections. I have just started watching his videos over the last half of year or so. I may, in the future, get some VOA's and UOA's from his business (but haven't done any yet).
Some people use an upper cylinder lubricant (TCW-3 or Marvel's Mystery Oil) in their cars and bikes at every fill up. I find that it is a hassle to carry the oil around to squirt the tank every time I stop at the gas station. I just want to fill and go.* All my cars have gone well over 150K miles without it and still running fine when I sell them, so I don't see a need for daily use.
* I added bolding and italics.
Yeah, totally get that. My bike has a pretty large tank, 4.5 gallons, and so what I've been doing is just filling up a 5 gallon gas container and using that. Lasts me awhile. I haven't done any longer trips yet, but I probably wouldn't worry about it during those occasional occasions.
Oil in gasoline lowers the octane. Lower octaine means it is easier to have knock and LSPI, especially in an air-cooled engine that runs hot. Both ^ of those can damage the engine and LSPI can actually blast a hole through piston(s).
So, if your going to use 2 cycle oil in a 4 cycle engine, you want to also be using a higher than normal octane fuel, so when the oil reduces the octaind it's still within safe range.
I know that's supposed to be the case but it hasn't been true in my particular experience. Dosing with TCW3 at 1:640 coincided with the disappearance of a slight tendency for my engine to ping. I have heard of another TCW3 user having the same experience.
Maybe there is some threshold before oil has a negative effect. My engine is supposed to use 98 RON but it runs fine on 95 RON dosed with TCW3.
That engine really likes to rev in the 300X. I think you would be better off using a good oil and oil change schedule than worrying about daily use of lubricants in the fuel.
My friend went one tooth up on the front sprocket for better highway performance (dropped the revs a bit). He rode the heck out of that bike and loved it.
Barring a wreck, this is my second and last bike. I want it to last as long as possible, and I'm really curious if I can positively affect valve movement (reducing it). But yeah, I get where you are coming from.
I just bought a gallon of Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend Engine Oil for just under $22. This one gallon will do me good for at least 35k miles.
Nice about your friends experience. Yeah, I have heard about that mod-haven't decided if I want to do that or not. I'm going to wait until I need to change the chain at least, if I do do it. (I plan to upgrade the chain)
One mod I plan to do in the near future is to make a removable homemade seat cushion booster out of latex foam-the longest lasting foam that I know of. The seat is not very comfortable. The longest ride I've done was 2 hours (with a short break half way in between) and while it wasn't horrible, it wasn't great either.
Cheers man
When my son was racing motorcross (4 strokes were new and only were lasting about 60 hours before needing a rebuild), I started mixing 1 ounce of 2 stroke oil and 1 ounce of a boutique fuel conditioner to every tank of gas. Don’t know if we just got lucky, or if it helped but we sold the bike with around 150 hours of hard use and the top end was fine.
I'm not a betting man Jimiii, but if I was, would put money on that it probably helped since you said the average at the time was around 60hrs. Not only did he go twice as long, but without a rebuild and with it looking good. Do you happen to remember what the tank size was?
Thank you for sharing!
Cheers man
I use an AirHawk seat pad on my seat for longer rides. It works pretty good. The trick is to run it almost flat, so that it squishes and distributes the air around all the uneven body contours. If it feels like you are sitting on top of a cushion on top of your seat, you have too much air in it.
