Originally Posted By: benjamming
Critic,
Don't take this the wrong way, but it is my opinion that TooManyWheels & doitmyself are spot on. Going by wrist feel is downright silly to put it bluntly. However, if you feel your PI is garbage, the USPS/UPS/Fed-ex man will gladly pick up your garbage & deliver it to me.
We use PI torque wrenches at work for nuclear applications. They calibrate/certify fine. I assume that your TW was bought new & came with a certificate of calibration? If not, you may want to look up
http://www.teamtorque.com/.
You're right, and I probably would've trusted the torque wrench 100% if it wasn't using it on a spark plug. But something just did not feel right to me, and I wasn't going to crack my cylinder head to find out.
The torque wrench was calibrated and I do have the original calibration certificate. I was probably using the wrench at the 20 ft-lb mark, which is the high-end of the recommended torque range for my spark plugs, which explains why something didn't feel right to me.
Originally Posted By: tom slick
The 20% of the scale makes a lot of sense but it's not what the USAF teaches, which is where I got my info from.
Critic, I don't care what you buy, I just hope that by playing devil's advocate I make you think twice. After come critical thinking if it is still what you need then that's great. Sometimes it seems like folks associate "best" as "most expensive" and the two really aren't correlated.
So who's right then, Tom? You or the the torque wrench makers? Now I'm puzzled.
I understand your concern and I appreciate it, along with the constructive criticism of others. At the time of the original post, I was probably a bit too excited about the Techwrench. Now that I've sat back and thought about it a bit, yes, I do need a quality 1/2" drive torque wrench to replace my HF clicker. However, a Techwrench may not be the answer since it is overkill for my application. After researching the Techwrench and learning that the overhaul cost is quite reasonable ($80), I'll still consider it if I can purchase one on eBay for $150 near-new. But considering their popularity, that probably isn't going to happen.
I did find a Snap-On QD3R250 torque wrench for $125 shipped from someone. The wrench has only been used a dozen of times and is in prestine condition. I may just jump on that deal once I figure out this 20% to full-scale issue since the QD3R250 has a 50-250 ft lb range and I plan to use it for torquing 80 ft-lb lug nuts.
