You've may have heard about this new CLP currently being tested at Aberdeen including the great results they're getting from it. I can tell you this lube (and I have a whole bunch others) works better then any other I've tried. It does not attract grit and can handle the extreme pressures of even the most robust civilian or military rifles and pistols. At 1,200 F spec, burn off will not happen. Cold temp the CLP will not gum up. It cleans carbon and fouling excellent and most all you don't need very much to clean and lube your firearms. This lube will stay on your firearm in your safe for a long time.
On their web page you'll see a couple types of lube, you don't need the military extreme only the red bottle Slip 2000 CLP.
I suspect this formula is an ester base, bio friendly, zero odor, and more importantly does the job.
I know I'll get other preferences from people but like I wrote I have a whole box full of lubes and haven't seen anything work as good to date for an off the shelf product.
