4WD
$50 site donor 2025
Looking on the Celanese site - 347°F appears to be standard grade (matches AC Delco info) but they make some AEM going higher …Ever burn one? Burn different than nitrile?
Seems high enough IMO - they come out mint …
Not much rubber in high temp oil/chemical resistant elastomers - lots of polymers and acrylics etc - kinda like a conventional and synthetic … whereas AEM has great low temperature performance as well …For all reasons highlighted by ZeeOSix in post #19, silicone is superior to nitrile for adbv. Especially beneficial over longer/extended fcis.
As for ACDelco use/promotion of "AEM", while perhaps better than nitrile, it's still rubber. My 'speculation', it would burn same as nitrile.
Then what happens ?Being that nitrile rubber is so much stiffer, it's going to be harder for the oil to push out of the way during entry.
Then what happens is I start worrying about it the whole time the filter is on the car. Not worth it.Then what happens ?
Nor is it worth this coming up over and over when nobody actually knows if it’s nitrile to start with - mine are not and they are not silicone - and they are not “so much stiffer” - not stiff at all …Then what happens is I start worrying about it the whole time the filter is on the car. Not worth it.
Yep. Full quart in my 5.3’s - Fram or AC Delco - so most is high side of the U-tube the ADBV held …An ADBV keeps oil in the oiling system when the engine is off. Not many engines specify a filrer without one.
I'm sure it's high temp resistant enough. My focus about burning one is to see if that can identify it from nitrile by the way it burns and smokes. Or does it burn basically the same as nitrile, and therefore can't be distinguished from nitrile by flame and smoke.Looking on the Celanese site - 347°F appears to be standard grade (matches AC Delco info) but they make some AEM going higher …
Not gonna stop no positive displacement oil pump, lol. And it will warm up soon enough as the oil heats up. It's more about the way it survives hot oil temps and long OCIs.Being that nitrile rubber is so much stiffer, it's going to be harder for the oil to push out of the way during entry.
AEM "rubber" quoted directly from posted ACDelco information. I allowed, it better than nitrile rubber. But then "speculated" as it's still "rubber" according to ACDelco it would burn similar to or same as nitrile rubber.Not much rubber in high temp oil/chemical resistant elastomers - lots of polymers and acrylics etc - kinda like a conventional and synthetic … whereas AEM has great low temperature performance as well …
“Rubber” has even become a phrase - like silicone rubber …
The semantics are on Wiki …AEM "rubber" quoted directly from posted ACDelco information. I allowed, it better than nitrile rubber. But then "speculated" as it's still "rubber" according to ACDelco it would burn similar to or same as nitrile rubber.
This much clear, AEM is not silicone, nor is it described as such by ACDelco in reference to AEM. Never heard of "silicone rubber" used as a manufacturer description or information about any ADBV, the topic of this thread. Beyond that no interest in further discussing the semantics of "AEM rubber".
Main point of my previous post first sentence on topic, silicone superior to nitrile for reason highlighted post #19.
Since I'm on ignore now I'll expect no reply. Never said, there was no such thing as "silicone rubber".
