SIG Sauer P320 self discharges
And this goes to my earlier point regarding, 'UDs could just be a matter of manufacturing tolerances or wear or whatever making some more 'loose' and prone to UDs while others are fine.'
My lightly-used (500-1k rounds) P320 has nowhere near the amount of play between the slide and the rails that the P320 in that now-famous video does.
Yep, seems that way.
Saddens me for Sig to have to deal with this. I liked my P320. We'll see what happens.
I unloaded my M18 and put it up in my gun safe. I won't carry or use it until Sig comes up with a solution that doesn't include blaming users, gaslighting or outright lying.
RIP to that young RIP. :(
I’m not familiar with the “now famous” video - got a link?
Like anything else that shows a "problem/defect", it is a small example of the total number of units it represents. So is it a widespread "defect" or is it confined to those examples in the videos? We don't know. The ones I have seen, have shown that in the case of some 320s (confined to those in the videos, and assumed as an acceptable representation), the striker safety is fully disengaged when all of the slack trigger travel (pre-travel) is taken up and the trigger is at "the wall" (about to fire). Is it responsible for the unintended discharges? Again, we don't know, but it does show that theoretically the gun can fire with very little trigger movement. But there still has to be trigger movement to "take up the slack" (pre-travel). Attributing it to "carbon build-up" as you said it rather far fetched IMHO because that would mean a gross neglect of basic pistol maintenance. 1mm of carbon would be quite a bit. Guess it may be possible because not everyone takes care of their firearms as they should. This is still not a defect that is attributable to design per se.
No one likes to have error pointed at themselves, and please don't take this as defense of Sig from some "fan-boi", but everything I have seen and heard points to some sort of error on the operator to some degree. Again, I use myself and my pistol to form this opinion as it has never had any unintentional/unintended discharges with mine. I am not a firearms expert or engineer/designer whatsoever, but have felt that for duty use, a better safety system should be used. A dedicated trigger safety that prevents movement unless the trigger finger is placed purposefully on it and defeats the safety would be first and foremost. And in the case of the striker safety being fully defeated with such little trigger movement, and thus being the only mechanism that prevents the striker from moving forward? Yeah, that's not ideal, again IMHO.
Even with all of the safeties in place, I have seen plenty of unintentional discharge cases over the years, especially with holstering/unholstering the pistol. Like it or not, all were from poor handling, or a foreign object interfering with the pistol being stored (holster), and not a design defect. Once the pistol gains a bad reputation though, it is an uphill battle to overcome it. It's the theory of reputation, ie; you can climb a mountain a thousand times and still not be known as a mountain climber. But do just one thing wrong and thats the label you now wear. But with this in mind, and the not most ideal (IMHO) safety mechanism(s) design, I do think Sig should take another look and address the issue in all of the pistols manufactured/sold. But thats just me. ***Activates flamesuit*** 😁
The video provides great views of the actual mechanical design flaw. No firearm should fire on its own period. Whether it’s cleaned or not. Even if it’s dropped from a roof top. Several owners posting videos online. All repeating the same results. Doesn’t sound like cleaning neglect. It’s a mechanical flaw. No soldier should doubt their firearm in the trenches because of carbon or dirty getting in the way. This user doesn’t even use the trigger trick.
There may be something here. There is not enough evidence to prove that there is.
Don’t like it? Don’t buy one.
This! More than one incident is clearly related to the holster. Others sure seem like negligent discharges while a few you just can't tell as a person on the outside looking in. I'm a Sig fan but I prefer the P series (220, 226, 229) not the ploy series guns. I do have a 365 but it is a Legion AXG (steel frame).
Thank you for the link.
40 minutes later - only one question: will it go off without a drywall screw in the action?
I don’t buy the “drywall screw is simulating a human finger”. What else is that screw impacting in the chassis?
