I posted a couple of weeks ago about a 2010 Sienna with seemingly poor a/c. Today's pretty warm, about 90-ish. I took it for a drive with a meat thermometer in the center vent, and here's what I found:
Recirculate on, max a/c, fan on high: 55 degrees
Recirculate on, max a/c, fan on medium-low: 45-46 degrees
Recirculate off, no max a/c, fan on medium-high: (WHAT I'D CONSIDER NORMAL SETTING): 55 degrees
Recirculate off, no max a/c, fan on high: 60 degrees
Clearly, this isn't enough to keep the van comfortable. I tested my Buick (2006, 150k miles, I think original R134) for a cross reference:
Recirculate off, fan low, temperature set to low: 38.5-39 degrees
Recirculate off, fan medium, temperature set to low: 42 degrees
Recirculate off, fan high, temperature set to low: 43.5-46 degrees
The Buick was plenty comfortable, and I had to turn it up a bit as I was getting too cold. The Sienna's vent outlet temperature was about 10 degrees warmer in similar situations, and it's unpleasantly warm. I think I'll take it to a shop, I called and got two non-commmital estimates (about $200, more if they find a leak). But these temps don't seem normal, do they? The consensus (kind of) was to take it to a professional instead of using a can of R134. Do my temps confirm this?
