Is my AC cold enough?
I forget if you mentioned whether or not you cleaned the condenser unit off...?
One other possibility...the evaporator may be dirty as well..but the only way to really clean is to spray foam cleaner up into the evap by way of the condensate drain tube.
I have cleaned the condenser and it made a marginal improvement, but an improvement nonetheless. I will look into cleaning the evaporator. I reached back there when I was inspecting my blend doors and such and it was kind of grimy/sticky back there. I also tend to get plant matter in my cabin filter for some reason, so there's no telling what's going on in there lol.
I have cleaned the condenser and it made a marginal improvment, but an improvement nonetheless. I will look into cleaning the evaporator. I reached back there when I was inspecting my blend doors and such and it was kind of grimy/sticky back there. I also tend to get plant matter in my cabin filter for some reason, so there's no telling what's going on in there lol.
I found this: https://www.lubegard.com/products/evap/
Anyone have any experience with the Lubegard evaporator cleaner?
Here is some of what came off/out of my evaporator when I cleaned it with the Lubegard. The laminate was perfectly clean beforehand. Looks like I should hit it again.
I've heard of the l
I've heard of this product but don't know how well it works.
Make sure you use the AC plenty after cleaning so the natural condensate fully washes off the debris and chemical.
