Poor a/c performance
Hey everyone so my 14 dart has auto climate control. Now that it is good and hot outside the a/c is poor. I noticed even on max with recirc on it blows at 50-55 degrees while cruising . I also noticed when I drive the fan speed slows down and when it does this the air temp gets warmer it'll do that for a minute or so then it'll come back to normal and be colder. The fan speed is the difference between max and normal a/c but the temp noticeably increases. I check the pressures yesterday evening it was 80 degrees out sun almost set and the pressures were 48/225 I believe it's a variable displacement system but not positive. What would you do or look at?
I would have it profesionally evacuated and refilled with a calibrated ac machine before any other tests.
48 on the low side is too much for only 80f. And 225 is pretty high. Sounds overcharged to me.
Originally Posted By: 5AcresAndAFool
Curious, what the AC like in the 13 dart you have listed in your signature?
Hers works great but different system I believe. So I was afraid to use it as a direct comparison . But hers runs at 40-42 degrees
I also thought it seemed high but since it's a variable displacement system I thought maybe it wasn't out of line. I thought maybe at hot temps the pressures are to high and it's kicking compressor off and on ?
Originally Posted By: Ethan1
How would a 3 year old car be overcharged?
It was a used car some people are just itching to fix it till it's broke .
I'll probably evacuate and recharge to rule that out regardless. Good starting point
Wouldn't surprise me if the car was wrecked and the AC was repaired and overcharged at a body shop.
yep or has air in it. Does not take much air to mess with pressures and cooling. Of course if the op bought it new and knows its history it cant be overcharged
I bought this one used. It wouldn't surprise me if its overcharged that seems to happen when a collision occurred or something else like a factory mistake.
I'm not sure what to think about it exactly. Going to start with that but besides that i don't know what to do.
The only thing to do is start from scratch. Evacuate the system, make sure it holds vacuum, and weigh the refrigerant charge.
Doesn't it have a warranty?
My Cherokee probably has the same system the Dart has, 92 today and it'll freeze you out.
Power train yes but bumper to bumper no.
Some automatic AC systems have codes they throw when there's something wrong, maybe this one does too? Dealer should be able to pull them. Worth the diagnostic possibly.
Yea i wish there was a way to pull the codes without a dealer
So I guess the general consensus is as I thought evac and recharge and see what I got?
I don't know much of what else to look at really .
I checked the freon level tonight 82 degrees high humidity numbers were 60-250
Fiances car was 50/215
So I evacuated mine and recharged and it is now at 51/200 it was cooling at idle to 41 degrees on high at center vent and it never did the thing where the air flow would get slower then faster ect. So tomorrow will be the true lipmist test. Hopefully that's all it was. Wouldn't it be great if my issue was a 10 dollar can of refrigerant
that might work in Manchester...
But I have plenty of acceleration potential, and get better MPG than your Scirocco. Impact on MPG is minimal anyway.
I wasn't comparing my car to yours, only confirming that by removing unnecceary weight and parasitic drag your car will be quicker and you will spend less on fuel. These are both good things.
When an engine is designed to produce motive force, using it for anything else seems wasteful.
